John Bozi
Etrailster,
You need two bikes. Get yourself a cheap hub motor hard tail, for the downtime days.
...I rode the motor to lock up at full throttle dozens of times, had thousands of carelessly hard starts, towed people up hills...So, my motor has been losing power. It just doesn't pull nearly as hard anymore and torque loss seems to be accelerating
John Bozi said:Anyone know if this sprocket would work with stock freewheel on LR?
Instead of joining it to the LR adapter, putting it on the opposite side of the freewheel...
http://www.sickbikeparts.com/catalog/product_info.php?products_id=66
I checked my measurements but I am not sure how they were measured and the LR adapter blocks one of each pair of holes.
I like this sprocket because it has that bend away which maybe maybe might not need so much of bushing or spacer....
or is this a bad idea?
I am trying to find a solution to chainring nut clearance.... (the wider bb in square taper will probably open up its own kettle of problems.)
The jackshaft axle is held in by a larger diameter center shoulder on the axle. The bearings press fit into the aluminum housing and hold that shoulder in place. In order to remove the old axle you need to use the axle to drive one of the bearings out. You can do this by striking the end of the axle with a plastic or wood shop mallet while holding the housing in your hand. You can also hold the housing and strike the axle onto a solid but padded surface like a carpeted floor or a block of wood with some shop cloths over it. It may take some work but there is nothing but a press fit holding the bearings in place. I have the luxury of using a 20 ton shop press with special jigs I’ve built for doing this.
To reinstall the axle, slide the new axle through the bearing that remains in the housing and then slide the new bearing into place. You will need to support the bottom end of the housing in a way that keeps the bearing in place but allows the axle to pass through. I use a 30mm thick steel plate with a 12mm hole drilled in it. You then need to use a deep socket or a length of pipe that is the diameter of the outer steel race of the bearing to drive the bearing back into the housing. Make certain that the socket or pipe has sufficient length that you’re not hitting the end of the axle on the inside. Drive the upper bearing in flush with the housing. If the axle turns hard after installation give the axle a few taps on the end until one of the bearings moves out enough to allow free rotation.
If the axle doesn’t want to slide through the bearings take a piece of emery cloth and polish the machined end of the axle. My machinist is obsessive about tight clearances. The shaft is machined to the correct diameter and then the 4mm keyway and spring clip grooves are cut in. Those cuts often create shoulders and sharp edges that hang up until they are polished down a bit.
LightningRods said:We're on final approach for the first production run of mid bike drives for the Luna Cycle. All of the parts are pouring in.
On the right is the original aluminum hub with ACS freewheel and 12mm axle. On the left is the new stainless steel hub with deep keyway, White Industries HD freewheel and 15mm hardened 4140 chrome moly axle. Both have my laser cut 40T #219 secondary sprocket. These are some pretty trick parts and totally necessary to stand up to the brutal power of the big block motor. More photos soon as I put the first four drives together.
Under 3kw, my lighter bike with larger wheels, saw me get to the top of this rough steep section at under 50 degrees, as opposed to his bogged in a rut 110 degrees.
DingusMcGee said:Bozi,
Gadgets: I see you measure temp with a Fluke? temp sensor. You could tell a more accurate story if you would acquire and use a digital level to measure hill steepness.
How about under 30% grade? I measure my slopes with a digital level using % grade as RO. You know the giveaway as to the real steepness in your GoPro video is that trees usually grow close to plumb.
LightningRods said:Yes I designed a completely different housing for the White Industries to allow for the different flange offset and the internal shoulder on the threads. I've been having them machined from billet T303 stainless steel. The sprocket offset ends up exactly where it was with the ACS and the previous hub.
I'm not following why you would need a longer jackshaft axle. But yes I can have a longer one made along with a batch of production shafts.
19mm axle diameter is too large to fit my current alloy housings. There isn't enough difference in the bearing I.D. and O.D. The bore in the standard 219 driver is .750", just slightly larger than 19mm. The largest shaft diameter that will fit my current housings is 15mm. Changing the housing diameter throws off just about every part on the top end of the drive.
So yes I can provide you with a hub for the White Industries freewheel and yes I can have a longer jackshaft axle made if you need it. You shouldn't need it because of the revised offset of the hub.
DingusMcGee said:WTF? No gates belts anywhere for the LRSB? The LR Parts store is out -- has none to ship to me? Other belt dealers are out of stock for at least 3 weeks until their supplier does a run.
Hi Dennis,
I just rec’d your E-S message. I did get this email. I’m low on belts. I placed an order for more on Monday and was waiting for a reply from the vendor before responding to you. They still have not responded. I’ll gladly fill your order as soon as they restock me.
Thanks,
Mike
These belts last a very long time. Especially on small blocks.
This does not belong on the E-S thread. Please take it down and I'll send you a PayPal invoice.
