I wan to test my battery module in a constant temperatures (both subzero and high temperature). I don't wan to buy thermal chamber because it is so expensive.
I would like to know do you have any suggestions or experience about it?
Note: the dimension of the module is following as:
Height: 300 mm
Width: 1900 mm
Length: 800 mm
Weight: 70 kg
Height: 300 mm
Width: 1900 mm
Length: 800 mm
Weight: 70 kg
