zombiess
I got a 18 FET 4115 controller and have just been looking through data sheets and playing around with numbers and trying to figure out realistic safe battery amp and max phase amp settings to program the controller to if I want to get totally crazy. I am running 30S lipo with a peak voltage of 126 volts on a 9C 2806 in a 20" wheel with vented side covers and 12 AWG phase wires.
IRF4115 says highest RDSon of 0.011 Ohm Max so for this example I'll say they are each 0.015 mOhm.
Max power dissipation at 25C is 380W with linear 2.5W/C derating so I'll say a 125 degree operating temp which gives 380-2.5*100=130W with an awesome heat sink. I'll derate that to 90W using the case as the heat sink.
So there are 6 per phase, 3 per high/3 per low leg of a phase. That means in parallel each three have a 0.005 ohm resistance total with 3*90W dissipation of heat for 270W dissipation per 3 total.
Since the FETs only care about the motor I'll use phase amps in this example.
With the above consumption each set of 3 FETs should be able to pass 180 Amps of current per phase wire before going pop. 100% DC * current squared * RDSon
Working backwards that gives us combined power dissipation for 3 FETs @ 125C of 270W / .005 RDSon for a total of 54000. Then take the square root of 54000 and you end up with each 3 FET bank supposedly able to pass a maximum 232 amps per half of a phase. If we go WOT we will get 232 amps of current per phase wire being delivered at 0 rpm. If we stick to the generally rule of running 2.5 to 3.0 phase to battery current that lets us with max battery current of 77 to 93A battery current. I typically aim for the middle and go use 2.66 time my battery current, so 232 phase amps / 2.66 = 87 battery amps maximum and you are now on the verge of making FET popcorn if the ones in your controller are 100% perfect to spec.
Since I never like to run things that close to spec if possible I'll allow 25% head room to allow for imperfect simultaneous switching times, losses/etc creating more heat or what ever other issues occur.
This I believe this leaves me with a general rule of them for my Lyen 18 IRFB4115 MOSFET controller of a max battery current setting of 65 amps and max setting of the phase amps between 162A and 195A for my 30S 126V setup.
These are just numbers that I picked from data sheets and hopefully got the math mostly correct. I would seriously appreciate anyone who knows more about this than me to double check my work. I tried to work with what I felt were somewhat decent safety margins by assuming really bad operating conditions such as 125C FET temps, not being able to fully drive the FETs into 100% saturation thus keeping RDSon higher than it's spec'd max of .011 ohm, etc.
These number also assume staring from a dead stop and just opening up the throttle 100% so everything gets maximum current. Phase current and battery amps drop from that point of course
These numbers all seem to match up very nicely with the ebikes.ca simulator. What do you guys think? Is my math correct? Is my derating good enough to find the theoretical maximum operating settings for my combo? Please point me in the right direction if I've messed this up royally.
Thanks,
ZombieSS
Thanks,
ZombieSS
