What is your inseam?
What about the sun ez-rider? Too long? Does have the rear suspension though not the front. 2005 Sun Bicycles EZ - Bicycle Details - BicycleBlueBook.comYeah, i have spent years trying to find a bike with just a slightly longer wheelbase and full suspension.
Of course the longer of semi recumbents don't have suspension.
I dream of that too.Long term i think building my own frame is the way to go.
I'm part of a very active and helpful BikeE facebook group that includes several of the original company owners/inventors who are very engaged/responsive. You should definitely join!The bikeE has very good geometry and consists of a giant extruded aluminum square with parts bolted to it. It would be incredibly easy to manufacture a v2 of and patents for the design may be expired / not enforced at this point.
And it's a story they've recounted a number of times over the years.A main thing i want to know is why the business failed, selling the most affordable recumbent on the market. That's the story i'd love to hear from a business POV.
As a bike racer / designer . . . measuring the weight balance with me on the finish bike as it would be used was always done.
Does the bike e bounce when pedaling?Phew, i'm so happy to see that!
Sounds about right.
What's your take on the geometry of the maxarya and it's poor weight balance?
Yes, but only if no gearing modification is made.Does the bike e bounce when pedaling?
Did you ever ride a bigha? https://www.bentrideronline.com/archives/reviews/BiGHA/bigha.htmYes, but only if no gearing modification is made.
For me as I use a Schlumpf ATS speed drive, while the 2.5:1 ratio is in use (almost always) I experience no bounce.
Also, stock the BikeE came with a 3 speed Sachs hub. This would also negate most of the pedal bounce in a similar way. i.e. if the pedal stroke can be decoupled from the power stroke through gearing, no bounce is experienced.
Cheers
From memory/summarised it folded because of Giant's corporate greed.
Giant made a deal with BikeE to help manufacture their frames out of Taiwan. It worked for a few years, but then Giant thought they could do better....out came the Giant Revive, and away went BikeE after Giant reneged on the deal leaving BikeE in the lurch.
I could be remembering wrong, but I think an entity still exists and holds the original patents and keeps them active preventing reuse.
If I were to make something new, it would probably consist of box sections large enough for 2170 cells, then I would play around with a bolt together Y configuration to see if I could cram 2 + 1 'rows' of cells in there. Similar to what I did with my CT internally, but split into the Y. If done right I reckon I could cram about 2Kwh into it and you would not be able to 'see' any battery.
I have a similar problem on my BikeE. I mostly don't worry about it as I barely ride on the road with cars, but when I do, I can't really look around properly, instead relying on sound, and reflections in my sunglasses to detect if a car is nearby.I find that with the seat angle on the 'middle' position, the bike is more impressive on pedal power but when i'm merging between cars and need to look backwards, i have to lean forward & twist my torso, which upsets the bike's balance. I find it kind of unsafe because the bike will be made so that it can blend in and out of car lanes.
