kje
fechter said:It probably went over the 63v rating and blew. Luckily, if that one goes, there's a good chance everything else will be OK. Just replace the cap. Even with a higher voltage rated cap, I wouldn't go over 60v or so. The output diodes will be next.
It's possible your 10k trimmer was set to less than 10k and/or the main adjuster wasn't all the way down to start.
You can use an ohmmeter to make sure the trimmer is at the maximum value before powering on. Make sure the main adjustment is all the way down to start. After powering on, you can tweak things gradually. Sorry if I didn't make this clear the first time. Ideally, you want the trimmer set so the main adjuster can go to maximum and be just under 63v.
Yes, that make sense. No need to excuse, this is a great learning process for me. ☺ I ordered a 1000uF 63V cap and will try again when it arrive. Thank you for your assistance.
