I'm leaving the first bike as it is and building a new one. The Planet Ryder motor is too large to allow any but the skinniest of tyres to be fitted. I'd like to reduce the weight a bit, too.... At the moment, the plan is to hang the batteries below the lowest tube.Wheazel said:Intresting, any special reason to change that old motor? Where are the batteries going?
Hi Savvas,samsavvas said:Hi Miles,
I have a TSR that is identical to yours apart from caliper brakes. I will follow your thinking with great interest, I tried to investigate your previous project but got lost at the sprague clutch phase. I'll try to understand things better this time around.
Hi Matt,recumpence said:So, what motor and what cells?
Miles said:Hi Matt,recumpence said:So, what motor and what cells?
I'll make the motor myself. Haven't decided which cells, yet.
The 125mm inrunner.madin88 said:Is this the 90mm inrunner or the bigger one you going to produce?
A 1080mm belt (Conti) with 90t and 15t pulleys gives a C.D. of 315.14mm, the same C.D. as on the MkI but, through losing 8.5mm on the motor radius, 1.35" tyres will now fit, but not 1.5". The nearest Gates belt is 1064mm.... too small. Conti & Gates both use 1120mm but that's too long to fit within the rear triangle using 15t-90t . 15t-96t gives a C.D. of 321.30mm with a 1120mm belt, which would allow the fit of 1.5" tyres. 15t-96t would be a ratio of 6.4:1.Miles said:Have to see how the centre distance works with available belt lengths, though....
Understood,.Miles said:I don't want to get into frame fabrication, at the moment.
Maybe you could design and build something that fits in the dropouts, that extends the wheelbase. Then you could fit bigger tires on both bikes.I'm leaving the first bike as it is and building a new one. The Planet Ryder motor is too large to allow any but the skinniest of tyres to be fitted. I'd like to reduce the weight a bit, too.... At the moment, the plan is to hang the batteries below the lowest tube.
Hi Mitch,MitchJi said:Hi Miles,
