mdd0127
- Joined
- Sep 30, 2008
- Messages
- 1,084
Hi Everyone,
I'm setting up a small parts fabrication shop in a 24 foot box truck so I can build a prototype ultra light electric dirt bike. Working my regular job and designing this bike is eating up all of my time. I have a ton of research to do and could really use some pointers on getting mobile power for the shop. The frame will mostly be 1/8" or less 6061 but there are a few heavier welds required. I had a Longevity 160PI Tig/plasma back ordered but their new shipment is behind and I need to get started ASAP so I'm now looking into a Miller Diversion165. I figured I can at least tack the thick stuff and get it welded by someone with a larger machine. I'm trying to figure out the most cost effective way of powering the shop and thought some of you guys might have some pointers.
First, I'll list the equipment in the shop, then my ideas so far for power.
Equipment:
Miller Diversion 165 tig 50A max 230V
Micro Proto 4-Axis DSLS CNC Mill 10A 120V
drill press 4A 120v
belt/disc sander combo 6A 120v
bench grinder 4A 120v
computer/monitor for mill 5A 120v
fluorescent lights 5A 120v
dremel tool 2A 120v
heat gun 10A 120v
lipo charger 10A 120v
bench power supply 20A 120v
oscilloscope 5A 120v
Total 230V amps=50 11,500 watts peak
Total 120V amps=81 9720 watts peak
I'll only be running the welder with about 30A input most of the time and would like to be able to have the lights on, mill and computer running, and have another 15 amps for extras. I'd like a generator backed solar system so I only have to run the generator/engine while welding or pulling a bunch of amps from everything else. I can also run a small ext cord from the house to help offset some usage, or top the batteries off on heavy usage/low sun days. I'll be using the shop daily and would rather rely upon the truck's engine for generator power because it's more reliable than a small chinese generator engine, and it's easier to remote start the truck.
Actual usage 230v amps=30 6900 watts intermittently
120v amps=35 4200 watts for 5-8 hours/day 175-280aH/day
I'd rather not have a generator running all of the time and running a separate service to it is not possible. It needs to be mobile. My budget for truck power is around $2-3K but somewhat flexible.
Here's watt() I've come up with so far:
230V generator options:
Northern Tool 230V 10kw generator head mounted in place of AC compressor on the 366 gas engine that runs the truck and belt driven, or mounted in box and driven hydraulically from power steering pump with hydro motor spinning generator head. Will a big ford ps pump sustain 20hp?
genny head $900
belt drive $60 vs hydraulic(preferred) $300
or,
10,000 peak portable generator. not sure of brand or reliability, not integrated with truck, lots of negatives
$1000
http://www.northerntool.com/shop/too...&ci_sku=162661
120V options
8 Kaneka 60 watt panels $500ish
Sun SM3624 3600 watt continuous inverter charger $550
4 120ah sealed 12v agm batteries $1200
So, the best I have come up with so far is:
230V intermittent system
hydraulically driven NT Genny head $1200
120V 480 watt continuous 5kw peak solar system $2250
Total $3450+ $300 for price fluctuations, shipping
That's way over budget for a system that might barely be suitable. As you can see, I'm in need of a little help. It would be awesome if I could just order a 15kw solar backup kit but that's definitely not in the budget! As least not yet!
Anyone have any suggestions?
Thanks,
Danny
Equipment:
drill press 4A 120v
dremel tool 2A 120v
heat gun 10A 120v
genny head $900
or,
$1000
120V options
Thanks,
Danny
