Hi mistercrash, do you really think it's bad to have regen in the cold? On the West Coast, daytime (riding time) rarely dipped below 0°C this winter. It often hovered around 1-2°C though, and I kept regen on. Doesn't seem like I harmed anything so far. For charging, I only plugged in when temps were above zero. I reckon I'd see a significant loss in range if cold regen was causing damage, right? I did get a range loss on a very cold day one time, but then on the next warm day I rode, I had all my range back again. In response to old posts:
Nice BMS! I love the displays. Putting it right under the seat is a great spot. Mine balanced my pack great (after a year, differences of only +-0.004V across all 20 cells), but the only way to check would be to probe each cell's BMS leads, located near where my feet go. Two weeks ago it got wet from water through the grill near the feet (poor packaging), and now I need to replace it. It was a 100A model connected through the charger port. Not a big loss since it was cheap, but I hope my cells stay balanced enough in the meantime. How long did you go before needing to balance charge? I remember you said you bulk charged for the week, but balanced on weekends, and it was unnecessary because "they stay so balanced it's boring". I lack the means to balance charge at the moment, but since these Leaf cells are so stable I'm not that worried.
mistercrash said:
Yes my regen works. It works on two levels, first regen happens whenever I release the throttle completely. The amount of regen is adjusted to your liking by putting a percentage value in ''RLS_TPS Brk %'' which I think is in the second stage of programming. Second, the other level of regen happens when I press a brake lever which activates the brake lever switch sending 12V to the tail light and to pin 2 of the controller which is the variable regen (or boost) function. I think a thumb twist throttle can be used to actually have a variable regen. Mine is just full regen as soon as that 12V signal is sent from the brake switch. Slowing down from full speed by releasing the throttle I see negative amp peaks on the Cycle Analyst of around -20A. Pressing the brake lever, it shoots up to as much as -60A peaks.
Oh you're using the throttle-release regen. I found it nice to set that to 0, so I can easily coast at high speed and trigger regen when needed for braking. I wouldn't want to slow down by default... but I guess you could still coast by holding the throttle open a tiny bit, no power. However, then you couldn't ride hands-free as easily 8)
Relying on my brakeswitch regen, I currently set it to about 30%. The deceleration is so fast. On a very wet day, I might lower it to ~27%, because any more and it's too sudden and easy to slip when it kicks in. It's simple to change using phone over bluetooth in seconds. I agree that our actual calipers are good enough. They also last surprisingly long. After 27,000km, I still have the stock one on the front (new pads this year), although I replaced the rear under warranty after it seized last winter (6 months after purchase, before I modded the bike) due to salty/slushy roads. I ride all-weather, even in snow, so I guess the salt from the road corroded the cylinder until it stuck closed. Regen handles most of the work anyway. At 30%, Stopping from speeds over 100KMPH can show >-120A peak
I once had to ziptie my rear caliper to my rear shock coil at the side of the road and make do without for a few days. I barely missed it, which shows how valuable it is :lol: . I mainly use my actual friction brakes (caliper/rotor) to hold still at traffic lights, and to stop for the last 10 feet after regen did 90% of the work. It's actually kind of fun to figure out the timing of when to squeeze in order to maximise power gain from regen, while still stopping perfectly where intended
Nevertheless, by my observation, regen barely gives the battery a powerboost. A gentle acceleration will usually use >3x the power gained back from regen, even if you get a hill on your side and are regen'ing for way longer than accelerating. Most of the time, even more power is spent maintaining speed (or accelerating more-than-gently 8) ), so regen gains are rather modest in comparison. Maybe 4Ah after riding for 55Ah. It's something, but it's not much.
Sorry to hear your charger died. Mine's been mostly fine lately despite it crashing out over concrete last September, which led to some issues (mainly switching from CC to CV mode, but nothing major). Recently, I swapped it with a buddy's EMC-2000 87.6V/20A because I thought it died (it was actually the BMS that died). It's pretty nice, with intermittent fans only turning on as needed, so it's usually completely silent, even when pushing 15A to the battery. After tuning the voltage down to 83.8V, I tuned the current down to 15A to 1) be gentle with the tech, and 2) not trip the house breaker. So far so good. It has an LCD on the side for voltage display, but it's not properly calibrated so I ignore it. My other charger tripped the breaker so often, even though it too was tuned to 15A (from 18A max), so I get the feeling that this one works better. It's also more efficient, judging by what it draws on the kill-a-watt screen compared to what the CA shows. This one draws 15A and shows ~14.2A on the CA (95%), whereas the old one drew 15A and showed ~12.8A on the CA (85%). (EDIT: This was actually due to the BMS. Without a BMS, my original charger now draws 15A and drives 14-14.8A.) Now you're on a Satiator eh... I find those to be nice little chargers to travel with, but at 5A, a little on the slow side. They're very sleek though, and easy to pack.
mistercrash said:
The power has to be cut from the motor when the brakes are applied, this is a safety feature that has to work on ebikes in Canada. It did not work, no regen and still power to the motor using pin 25. After talking with Fany at Kelly Controllers about it, and finally determining that pin 25 was doing absolutely nothing on my controller, Fany told me to use pin 2 which works like a charm but, I lost the option to have a boost button. I was contemplating to have the top speed programmed to 32 km/h and have one of the two horn buttons serve as a boost button, releasing the full power of the system on demand. But I can't have both regen and boost working at the same time.
It's unfortunate you had this issue because it should be working 100%, however, I wouldn't sweat it Ray. Boost is not good. It doesn't just unlock the bike's top-speed, it actually delivers max power when you trigger it. I had a switch wired to boost one time, and when activated, the bike would lurch forward in 100% WOT. With torquey bikes like ours and such high speeds, that's not good. From 32KMPH, you'd be over 90 in like... two seconds. It's better to manage that acceleration with a throttle, spending time at 50 or 70, and not top speed. To maintain less than topspeed with boost, you'd have to pulse so often you'd be wishing you were just holding a throttle. Plus, pulsing maximum power draw is hard on the tech. Therefore, 32KMPH regulated topspeed with a hidden go switch may be stealthy and cool, but would be hard to control and potentially hard on the battery/controller/motor. Legally, it wouldn't matter if you got caught going over the limit anyway. May as well just quickly whip out your phone and set topspeed to 32 while the police officer runs your license through his computer
I originally wanted my 3-gear switch to be reverse, low-speed, high-speed, but couldn't find a way to make that work using the boost function.
So for your pin 25, I imagine it didn't just fail in the connector, but actually failed inside the controller, or was broken due to some logic issue. That sucks, because you probably can't fix that. Those pins in the connector however, I'm getting tired of them. Ever since I got sprayed with a fire extinguisher (yellow powder, long story), they've been corroding and failing. At first I would replace them, but then the plastic started wearing out, and the pins became unreliable and kept breaking off the wires, so I ended up hardwiring the whole motor plug to the Kelly and just chopping off the connectors. Bulletproof since then. Of course there are other issues, but no more getting stuck at the side of the road trying to troubleshoot a hall sensor lead while trying to get somewhere. Imagine it was raining, it's just not a good show.
Lots of minor issues elsewhere though
For example, my 3-gear switch liked to leak voltage when it rained, and that sometimes stuck me in reverse
or without any throttle at all. That got fixed once I swapped the switch out, but then one time it rained and I lost power to the motor while driving. I opened up the app on my phone and realised it thought it had a brake pedal, with the value reading 255... so random and sudden. Once I saw that, I changed the "brake type" to zero and rebooted, and boom, power restored. Things like that happen all the time, and probably will continue to until I get off this macgyvered Motorino and redo all the wiring from scratch, focusing on waterproofing, quality wire, and minimal failure points (as few connectors as possible, more hardwiring, extra solder, heat shrink and tape everywhere). This is going to happen on the new frame, on which I plan to really take my time setting up.
I'm on the hunt for the exact right motorcycle frame. I want to fit 24 modules, 24S/4P. That would be 88.8V nominal (100.8V full), and double the range (120Ah/charge). It's pretty crazy, but I think it's just barely possible if I get a bike frame with wide, double-front downtubes allowing the modules to be stacked on their edges (like CDs on a shelf). I'd build two rows. Custom welded box over that. This would of course take my Kelly 96501-8080I a tiny bit above it's rating (96V max), but I don't think it will cause an issue. I've seen guys at 90-something volts on controllers rated for 72. Worst case, the Kelly doesn't accept it due to a firmware setting, and I charge the cells to only 4.00V = 96V, sacrificing a tiny bit of range... or drop to 22S for 92.4V full charge. I think the voltage makes a lot of difference in top speed though. Maybe 3KMPH/volt. I know it's more weight, but no worse than having a passenger. I often take people around, and still can perform well. It'll be more stable, and legal, too, which I guess are plusses. Until then (maybe in the fall), I'm really enjoying what I've got each and every day!
