John in CR
100 TW
Like many, I've had it with blown controllers while shooting for higher power. I can't rewind my motors for 6 or 9 phases and simply use 2 or 3 controllers, because the darn stator slot count is wrong and are 3 times a prime number, so it's either 3 phase or that prime number of controllers with one slot per phase and that probably would put the resistance too low anyway.
What about splitting the winding terminations into their separate strands, and then separate them into 2 electrically isolated groups to run 2 controllers? That doubles the winding resistance each controller sees, which I think is a good thing, but doesn't also cut the BEMF by half? My biggest worry is about the resulting parallel coils that are intertwined. Will those coils interfere with each other?
I have a motor with dual halls already installed, but the halls are on slightly different timing, one for torque and one for speed. Wouldn't that really make a mess with coils so parallel?
What do you think, potentially a good idea and worth the risk of messing up a perfectly good motor, or bad idea because the controllers will wig out?
If it has potential, I have another candidate, a dual tap x408-4011. If I separated the windings at the tap and ran them both at the same time with 2 controllers, one would be running 8 turn windings and the other 3 turn, which might be interesting. This is way different than the route discussed above, where the controllers run on identical count windings, just lower strand count copper for each.
John
John
