HrKlev said:
andrea_104kg said:
I can confirm that the torque sensor cyc works with the lishui control unit sold on aliexpres, only I have problems the engine continues to turn for 3-4 seconds after I stop pedaling and this is very dangerous. It also starts immediately at the slightest pressure on the pedals
Ouch, 3-4 seconds overrund doesnt sound that good. Any way to program it?
And how is the motor you converted running? Its a very interesting thread, but google translate makes it a bit hard to get all the details
ok, I'll try to explain but for now I can't try the bike, I have to get the sprocket, it's all very experimental, maybe it will only last a few meters
The motor is a front q100h at 36v, 201rpm, however my battery is at 48v, so it will do about 330rpm at no load.
I opened it by making myself a special tool
inside you know him well ...
I disassembled the plate with the pin and I filed the 3 protrusions below with the iron file
Then I adapted the holes to put some screws and screwed the freewheel into the 3 holes. By a lucky coincidence the 3 holes coincide with the original holes
I put a sheet of Teflon on the engine cover so that the freewheel did not make friction, then I reassembled everything, before closing I put a shim so that the plate remains raised from its original position and does not scratch
In this way the axis rotates when the motor is operated
[youtube]https://www.youtube.com/watch?v=vhUpHW5zvXw[/youtube]
then i bought the lishui controller on aliexpress and the torsometer on cyc motor. I bet they worked together, and in fact they work.
I then built the attachments for the motor with a 4mm steel sheet
however the control unit does not seem to manage the torsometer well. There is a great delay in stopping the engine.
[youtube]https://www.youtube.com/watch?v=OnhNmtlJRl8[/youtube]
The ECU options seem to have no effect, there is no difference when adjusting the sensitivity or force on the pedals.
For now I can't test it on the road because the pinion turns on the axis is not strong enough.
Sorry, i use google translator, i hope it's possible to understand :-(
