Its been a little back and forth with motors on this bike, but when the tsdz2 burned, I needed to put something together on the FS bike again. I already had a torque sensor and freewheel from the CYC X1, a cycle analyst, and a MY1018 brushed motor. So I converted a bracket to fix the motor to the frame.
Here's the torque sensor and freewheel. I used an old chainring from a cyclone kit to make an adapter from whatever BCD the freewheel is to 104bcd, and attached a 32T and 44T chainring to it
View attachment 278886View attachment 278887
The 44T was later replaced with a 48T. After a lot of tweaking with the cycle analyst the bike behaves quite good now. But, the MY1018 is very loud, and not very efficient when it is not in the peak powerband... The tsdz2 got me a lot longer on the same battery. Doing drops and jumps without fearing that the spindle would break was awesome, though! The added ground clearance is also a very welcoming change.
The bike now weights 20.2 kg, so not too bad. The MY1018 must go, though. I have decided to go with a small, geared hub motor that will be mounted as a mid drive, and a baserunner controller. The baserunner has a unique(?) feature to simulate an electric freewheel for use in the clutchless GMAC. I think this will work very nice to keep the motor running and keeping tension in the driveline when not pedaling, so I get instant reaction without the jerk that happens when the motor catches up with the driveline. I have also ordered a Bafang G310 (2.5kg and a AKM/cute XS75 (1.4kg). If the XS75 is powerful enough, I will use it for the FS bike, and the Bafang for the fatbike. Because of reasons, the completition of orders and shipping takes forever, though, and in the meantime Im grinding away on the MY1018.
