Doctorbass
Simply incredible!!!.... I repeat INCREDIBLE!!!
After waiting for long time about my fet order, i finally received these. I am very happy cause it's now time for high voltage fun! I waited 1 month to comeback with my 66 or 72V setup... i waited using only at 33V during the entire last month... :x
I installed these on my controller today.
-upgraded the + and - rail bus bar with 3x 12 gauge wire close to each phase fet group
- replaced the ramp capacitor to a 2.2uf instead of 10uf
-replaced the fix current limit R13 with a 10 turns pot to get variable current limit and allo the shunt to stay intact for my cycle analyst
-Decreased the LVC to 25V instead of 29V (when using with 1s 4p dewalt pack.
-changed the pos and neg power wires to 8 gauge
-re positioned my battery pack holder in the triangle instead of the rear rack... my bike is alot mure stable and weight balanced!
-AND I finally TESTED!!
First i was nervous about powering it and risk of blowing my new fets.... but i was lucky... I double checked each solder, pcb traces, polarity.. etc
I installed my DC clamp meter with peak hold on one of the battery pack wire (tested at 2s2p pack =67.7V standby)
I started by puting the pot to 1 turn out of 10. and put the throttle to the max quickly. I recorded 9.9A
i increased it to 2 turn.. I recorded 14A and observed that the acceleration increased significantly...
..... 3 turn...
7 turn and reached 48A... WOWW !!!! Too much torque!!! I simply do a wheelie when i put the throttle to the max!!!... I need to go to the front of the bike to keep the front weel on ground!!!!
that's 2640W at 55V ((due to the A123 cells at 10C) 2.8Vx10cells x 2s=56V)
Oupss... I remembered that i also installed a 40A fuse inside the controller to protect it... maybe i should be carefull with this pot...! :wink:
maybe also i will install a torque arm.. I know.. I know... .... for sure i will!!
I just can't imagine if i increase it again... again to 8 or 9 turn..!!! the R13 for current limit goes to around 310ohm if I remember...
I climbed a long hill near my house and I got 42kph !!!.. I when i come back i got 67kph on return... and 52 on flat... (i'm at 66V ) I got also 57 on my old 72V SLA..)
I will get my new GPS and will post the slope value of it soon.
I also have 3 more dewalt pack to install (the one i got for free..)
I am simply amazed!! happy !... and proud of that installation!
Doc
