The7 said:
xyster said:
The7 said:
Did the 2.5s ramp time occur at no-load
Wonder if you could do an simple experiment on your ebike 5304/20?
With the drive wheel off ground, give an quick FULL throttle and note
a) any delay time for the wheel start to rotate;
b) time for it to ramp up to no-load top speed: and
c) the battery current during ramp up.
I did the test myself on AL1020 using 36V at no-load.
Two ways to apply FULL throttle quickly:
1) Twisting the throttle to FULL as fast as I could;
2) Press the brake, turn the FULL throttle. Release the brake and the throttle will be at FULL.
These two ways gave practically the same results .
1) There is a small LAG. Seems to be the order of 0.1s.
2) The speed ramped up to no-load top speed (45 km/h) at a short period. Seems to be the order of 0.5s.
3) An digital ammeter and an analog meter were used to read the battery current. During the ramp up, the ammeter never exceeded 4A. So the current limit (20A) was not reached for such no-load test.
Comment:
1) It seems the order of 0.1s LAG is not desiable.
From memory of motor-cycling in young age, there was no such LAG feeling.
Thinking of changing the 10uF to 1uF may reduce this LAG.
2) When the ebike was loaded (road test), the ebike reached its current-limit (20A) every time at FULL throttle. In such case, the ramp up time (order of several seconds) will be dictated by the current-limit, and the top-speed by the battery voltage.
3) Don't think that there is any other ramp up circuit other than the "soft-start" 10 uF capacitor.
Would like to hear what is your experience.
