Hi,
After a delay, I am working on getting my ebike set up and could use some help. I ordered a Mac 10T upgrade kit from EM3ev with 9FET controller (IRFB3077) and Cycle Analyst V3 along with the 48v 24.8AH High Energy INR18650-29E Battery. I am running this system on 700cc touring bike. It cost a lot, so I would like to set things up to make it last...so a few question:
- What should be my low-voltage cut-off value in CAV3? Paul has 30V programmed into CA, but that seems way too low. Can anyone tell me what this number should be? I want the battery to last as long as possible. He has also programmed 800 into low voltage feedback gain - I am not sure how this works - does that seem right?
- What should I program into CA for Max and Threshold Temperature for the 10T motor?
- What about "Power limit" for motor. Paul has programmed in 1500. If I want this to last, should I lower this number or will this work fine?
- I don't care about being fast from stop, but I would rather have motor last as long as possible. What should I set my ramp up, ramp down, fast ramp up numbers at?
Thanks for all help!
