lawson415
Hi All
Some newbie questions:
I just wired up and intsalled a new ping 36 v 20ah battery. I am using an Ebike controller and CA with a 400W Ebike geared front hub.
When i first plugged the battery into the controller, I got a little spark. After that, i could not get anything out of it- no lights or text on the CA.
I took ping bat out and reinstalled my Ebike battery and everything worked fine. I took the bike on errands and returned in several hours with a volt meter. I checked ping battery voltage and polarity- it was 43V and polarity was correct. I unplugged and repluugged in the bms and everything worked. I took the bike out w/ the ping and went up several steep, long hills. The battery cut out and would not start after drawing s/t like 1150 w. I pedaled home and set the Ca to limit the max amp to 28 A.
The battery worked fine after tis on test drive w/ some hills until I got on a rough road with lots of bumps and pothols. After hitting a big pump at a bpout 10 mph, the battery cut out.
I unplugged the bms and replugged it and the battery came back.
I have charged the battery 3x- once when it arrived and twice today after running it down about 2AH. All lights on the bms came on each time I charged. BTW, the bms gets pretty warm when charging..
What do you all think is wrong?
Regards
Robert
Regards
Robert
