thineight said:
Please tell me which model of case you bouhgt from em3ev.com because 14s4p is even more of what I need. For my use a 13s4p is ok.
I do not understand how you remove the battery then, looks like you can't move it forward to disengage the cradle.
This is the battery I have, they do sell 13s4p battery as well but the case is the same.
There is a little it of space in the uppermost corner and I also filed 1-2mm off from the case, the fitting is actually so tight that the couple of mm makes all the difference wether I can remove the battery or not, first I had to remove the rear shock bolt to fit the battery in place. I also turned the rear shock upside down from the original build, that also gave a little bit more space. And removing the battery is quite a complex motion of pushing it forward, then tilting and finally twisting to the side.
It seems that your frame is way smaller, what size is it? Mine is L. I put my rough measurements next to yours in the image. It seems that similar case will definetely not fit your frame :/
