ornias
- Joined
- Jul 18, 2021
- Messages
- 172
endlessolli said:Elinx said:Only till about 2018 tsdz2 had straight gears, after this date all have helical gears.Piper J3 said:..... TSDZ2B which I think has helical gears on the right side. I’m I correct that the “B” has helical gears?
The difference with tsdz2B is the double sprag clutch on the main gear, which has nothing to do with helical or straight gear.
Straight gears were indeed noisy, but the whining you have must have another cause
There is this quote indicating that replacing the bearing on the speed reducing shaft with a high quality one greatly reduces noise:
https://endless-sphere.com/forums/viewtopic.php?f=28&t=79788&start=9425#p1725515
I never tried it, as my motors are not that loud (or our ears are not that good anymore…): The 2 motors currently in use were bought used and we have put 1500 additional km‘s on them w/o issues. Noise is not that loud.
To be fair, with the relatively low costs of bearings: Just replace them all with good quality japanese bearings if you open it up anyway and add the few on the usual spots.
Including replacing the clutch for a 140nm rated BB30-1K-K instead of 110nm rated standard clutch bearing.
