donn said:
I'm surprised, though - wasn't it you who reported that even torque sensors don't give you anything until you get the cranks moving?
That is only on devices that *also* use the input from a cadence sensor to detect that and require it.
A device that only uses the torque sensor itself would not require (or even know about) crank rotation. For instance, something with a torque sensor like BeamTS, that measures only chain tension. Or at least one of the Stromer models, that measures torque on the rear dropout. Or BionX, that has a strain gauge on the axle (I don't know if it has a cadence sensor).
But a torque sensor (with or without cadence), properly setup, shouldn't cause a launch from rotating the crank with no load, only if you took up all the slack and then pushed on it. It wouldn't generate enough signal before taking up the slack to trigger motor activation. (if you push on it hard enough, then it would engage the motor, of course).
However, a cadence sensor, if setup to be sensitive to a small portion of crank rotation, could easily cause this, just taking up the slack in a chain.
A trackstand isn't necessarily incompatible with a torque sensor, but would probably either require an electrical cutoff (button, brake switch, etc), or a cadence sensor that requires more rotation than you would ever do on a trackstand, or a lower limit on the torque input that is above the force required to do the trackstand. Either of the latter would be a problem for anyone that needed to be able to start the motor going with less pedal force than that needed to get going by themselves...but they probably wouldnt' be doing trackstands to start with.
But you could also create a delay requirement--any input to the torque sensor would be delayed before the mtoor acted on it, and if the torque did not stay at or above that level for the entire delay, it would not activate the motor. I don't know how well taht would work in practice, unless you also tied it to the speed sensor such that it only occured at zero speed, and there was no delay above that. It would produce undesired delay in starting up from a stop, though.
A simple cutoff switch is probably the easiest way to deal with the problem, whichever way you are controlling the motor via pedals.
