Parking and Brake lights Kelly ctlr kbs72121x
You should also be able to go based on the wire colors.
Inside the controller is just a big molex type connector.
I have an old kbs controller disassembled so I guess I could help if he wants to go that route.
here is the link to the kit http://www.eastgem.net/d4500-k-1.html .... I haven`t try to open the controller before but according to the manufacturer he sells a complete set of cable for all the lightnings .... but the option of wiring it myself is there and that`s what I`ve been trying to do
What a terrific link. Nice to have kit makers that supply wiring diagrams! :)
It looks like the wire number designations are the same. So if you where to pull the pin out on #1 from the connector as seen here...
And connect it to the blue wire as seen in my previous wiring diagram that goes to the 12vdc + brake light switched power. And having already set your controller parameters to use the 12vdc input as opposed to the temp sensor, all should be well.
Link to full wiring schematic of kit harness.
http://www.eastgem.net/assets/denzel-kit-4500k1.pdf
This will lose your ability to use the motor temperature sensor if that is important to you. There are other ways of doing it with out using this pin, which would require a simple 12 vdc relay if you so desired.
Regards, T.C.
