Twelvebears
- Joined
- Apr 4, 2019
- Messages
- 12
Hi All.
I’m using a Phaserunner on my wheelchair power drive and will be updating to the new V6 + CA WP to get a tidier, wiring setup.
I need to be able to use the reverse function and I’m not clear how this should be connected - has anyone else used this?
The PR manual indicates that the PAS 2 wire in the 6 pin HiGo plug (presumably via a switch with the ground wire) enables this, but it also makes reference to Digital Input 1 (Cruise) which I thought was a connection to the CA.
I’m just trying to clarify if I can configure the reverse function via the Digital Input 1 on the CA or via the PAS 2 wire in the 6 pin plug on the PR (or is it that either of these will work?).
Sorry for the stupid questions.
