LI-ghtcycle said:
I have to say, if there is going to be a serious race, get ready for the mid-drives to walk away from the hub motors!
mmmkay, don't see how the hub debate was anywhere on the radar to what's being discussed.
but if you really can't help yourself & just
have to get in your swipe then i guess i just
have to rebut.
the problem with a hubmotor is that it is stuck in one gear, n'est-ce pas?
it's efficient at only one particular rpm.
in normal road racing where speed is never constant, you're relentlessly accelerating (either positive or negative) a hubmotor is at a decided disadvantage.
well, that along with it's higher inertial mass it sucks ballz really.
however in applications that run mostly constant speed without wavering off it's efficiency peak too much is
precisely where a hubmotor is in it's element.
that's why a hubmotor works reasonably well for a commuter bike.
the overall percentage of time spent off-peak spinning up to speed is relatively low.
and climbing a mountain is even more steady-state constant rpm than commuting.
the terrain may vary a little but it's basically a pinned throttle race.
ask the opti-dweebs how much use they got out of their gears.
they said the first six or almost half their rohloff was dead weight.
really, if there was ever a race tailor made for a hubbie, pikes peak is it.
LI-ghtcycle said:
Sure a hub motor properly modified/specialized for the specific task will be competitive, but if it's limited to the same weight, watt hours of battery and motor wattage, a properly sorted mid-drive type E-Bike is going to beat a hub motor every time. Sure in a Drag race or some similar event that might not be true, but in true endurance test like this event, efficiency & power delivery is going to trump a big motor every time.
never heard of the CSIRO solar car hubmotor?? (i think you have).
don't know what size mountains they tackled but regardless the motor can't tell if it's pushing against the wind or pushing against gravity makes no difference.
history has already proven you wrong that it's the hubmotor that can't be touched for efficiency.
actually you sound a lot like josh's
friend who attempted the climb with him last year.
he wrote off hubmotors completely from his wild extrapolation based on a few meager data points.
John Bidwell said:
Learnings and take-aways are:
There is nothing like a derailer geared electric drive for efficiency on
steep hill climbs. All who made it were derailer geared, and all who didn't
weren't.
well mr. bidwell, the stromer (a hubmotor) almost made it going 24 of the 26 miles falling short only for the want of miscalculating by a few amp-hours.
he had 720Wh compared to optibikes that came equipped with over 1 kWh packs.
not much of difference in energy consumed either way.
