WIn the brief time I used it, I had no problems at all, but this 3220 "direct drive" setup just makes way too much racket, for my tastes...
...I hate the direct drive setup I have now because it just makes such a horrible racket...
...The problem with trying to do a direct drive ratio of 8 or 9:1 is that the drive sprocket needs to be small and that means it will make a lot more racket...
...At some point I'm going to change my 11t motor sprocket to a 12t, which will bump the top speed in 1st to about 20 mph. This should also reduce the horrible racket my setup makes. That is the biggest problem with not having the belt drive 1st stage, it makes a horrible amount of noise, which is made worse by the small 11t sprocket...
...with the "direct drive" setup I did with the 3220 and the large #35 sprocket. That too sounded like somebody dumped a bucket of bolts into the spin cycle of a washing machine...
... due to the chordal effect. It is hard for a chain to get around a sprocket that has fewer than 11 or 12 teeth. It ends up sounding like bucket of bolts in a washing machine...
