I've read a variety of posts referring to sensorless controllers but have failed to identify any significant advantages or disadvantages other than:
Pro
Does efficiency change?
Is field weakening as effective or not? (it seems it is, but not totally sure).
Are there specific conditions other than startup that sensorless struggles with perhaps?
Are there other particular advantages?
I'm wondering if sensorless might be a good option for a trials bike?
That seems perhaps counterintuitive given a trials bike often runs at very low RPM but the thing is, even with encoder based control they still can't pickup satisfactorily from stalled. Not necessarily due to lack of torque or control from the motor, but because the rider can't deal with the shift from stalled to driving. It's way better to have a mechanical clutch to use at the transition from stationary to moving and set the motor to always idle. There's more, but that's a simple version.
Given the bike has a clutch and the motor is set to always idle, I'm trying to work out if there is any reason why (or why not) to use a sensorless controller?
I should add, I'm envisaging this on a IPM motor such as the QS165 V2.
Cheers.
Pro
- No need for sensors. Duh
- Startup from stationary can be less than ideal. ie sometimes it wont, or it does but with reduced torque.
Cheers.
