Hello,
I'm still trying to find a workaround for programming my 18FET PowerVelocity controller. It's bluetooth programmable, but it appears to be an older (internal) bluetooth module that doesn't work with the current version of the bluetooth app. The problem is, there doesn't appear to be an older version of the app available.
I've also looked for information related to programming the Xiechang 18fet 4110 Controller, which may be the starting point for the PV controller, and saw a video by West Coast Electric Cycles programming the Xiechang controller via a USB connection and XPD software. I haven't opened up the controller yet, be expect to see the bluetooth module, plugged into a programming interface that would work with the USB connection, and hopefully the XPD software (the settings in the XPD software look very similar to, or maybe identical to, the parameters used in the current bluetooth app).
Anyway, before trying this last ditch attempt, I'm wondering if anyone else has successfully programmed their PV or Xiecheng controller with XPD, or tried unsuccessfully.
Thanks in advance for any insights.
