Hold the phone.
I discovered something today that significantly changes how I can use the BBS0X system. If it is documented here on the 'Sphere somewhere I guess I missed the memo.
The assist level speed percentage limits the top speed with pedelec. For example, setting maximum speed in the menu to 50km/h and setting speed percentage to 64% nets a legal 32km/h maximum assist speed in pedelec mode. But this speed percentage value actually limits BOTH the cadence and the top speed at the same time. So the power level also diminishes at a certain cadence.
Presumably, the cadence limit is a percentage of maximum cadence. I haven't confirmed this yet. If so, playing around with maximum speed and percentages will result in different cadence limits at which power assist diminishes for a given assist level speed percentage. An interesting effect of this is that a gear ratio change which results in a lower cadence brings back the assist. Eventually the power level is diminished entirely by attaining the maximum set speed.
It soon became apparent this could actually be used to aid with shifting. For example, after accelerating to the cadence limit, there is no longer any assist power on the chain so a smooth shift can be made without applying any brake or other throttle cutoff. Then after achieving the cadence again the power drops off again and another shift can be made - and so on until the maximum speed setting is reached. This approach works quite well in most situations and I'm surprised I haven't seen anything written about this anywhere.
With this method, less time is lost without power and close-ratio shifts are a bit faster and certainly easier. If the display shows power (C965) then shifts can occur as the value approaches zero. It is also possible to go by feel. This doesn't work so well if climbing a steep hill and the rider power input is too small to get the assist level close to zero.
Anywho, this was a pleasant surprise! And one of the coolest things about this is throttle override provides full speed - like when you witness a robbery and need to catch the bad guys.
The settings I have been experimenting with are shown below. Maximum speed is set to 50km/h in the menu. The 64% assist level speed limit nets about 32km/h maximum speed in pedelec and the 50% assist level speed limit nets about 26km/h maximum speed in pedelec.
