CAN I USE THE BMS THAT CAME ON MY PSI 24 VOLT LIFEPO 4 BATTERY ON A PING 24 VOLT 20 AMP BATTERY THEY ARE BOTH 24 VOLT BATTERYS THE PING IS 20 AMP AND THE PSI IS A 10 AMP ITS JUST I HAVE A SPARE PSI BMS AND WOULD LIKE TO USE IT ON MY V2.5 PING PLEASE LET ME KNOW IF THIS IS POSSIBLE I THINK MY PSI CHARGER SHOULD BE OK ITS 24 VOLT{29.6 VOLTS} AND CHARGES AT 5 AMPS
