QSMOTOR,0.5-12kW Electric Hub Motor & Mid Drive Motor Manufacture China
QSMOTOR said:
Really sorry we could not provide the 3D CAD drawing for the motor, it is related with our business secret.
But if you bought the motor from us, and really need it, after we sign NDA, we can provide it to you separatelly.
Thank you,
Judy
Your engineers could simplify the 3D model (no need to show internals) and export it as STL file. I'm guessing the 3D model would only be needed to design mountings and other related items on e-vehicle, so only external dimensions matter.
You do have 2D drawings (but one has to be very persistent, trying to find those) of your motors, showing external dimensions, so it's not that big secret.
http://cnqsmotor.com/en/article_read/QSMOTOR%20138%203000W%20V3%20Mid%20Drive%20Motor%20With%20Gearbox/1022.html
Thank you,
Judy
Thank you for your suggestion, we will consider that.
Hi QSMOTOR,
Do you have a bracket for the model QS138 70H v3 to mount on a regular bicycle?
If Not, I will have to design and cut one but I have no idea how I will do that. I even dont know how to use 3D modeling.
I hope you can help me.
Thanks
QS NEW 180 90H Mid drive motor available
The new 180 90H mid drive motor use encorder board to in stead of hall sensor, which will be more stable.
Below are the pictures:
For the controller, we plan to match with Far diver controller, it is going to test.
For the motor, we still have about 10pcs material in stock, so if any need, pls contact judy@siaecosys.com.
Thank you,
Judy
brazilianboy said:
Hi QSMOTOR,
Thanks
Could i know where did you from?
We have a customer from Netherland who can do that for you.
So if you want, i will ask him to contact you.
Here i attach some Installation inspiration for you, pls check.
View attachment Installation inspiration for QS V3 Mid Drive Motors V1.0.pdf
Test report of QS 138 90H 4KW mid drive motor with Far driver ND72530/ND84530/ND96530
Pictures
Spec of controller
Testing report.pngTesting report in 96v
Any question, free to contact judy@siaecosys.com
macribs said:
QSMOTOR said:
QSMOTOR 180 9000W 90H PMSM IPM mid drive motor
For a long time, we are developing and testing our new 8000w mid drive motor, below is the result
For Motor
Item: QSMOTOR 180 9000W 90H PMSM IPM mid drivemotor
SPEC
·Motor Type: PMSM IPM Motor With Hall Sensor
·Rated Power: 9000W (18000kW peak in few seconds)
·Rated Voltage: 72V
·Speed: 4000RPM peak (basic RPM), 7000RPM with flux weakening
·Max Torque: approx 100N.m peak.
·Max Efficiency: approx 95%
·Continuous Battery Current:200 A (72V)
·Peak Battery Current: 250A (72V)
·Working Temperature: 70-130℃ , peak 180 ℃
·Single Hall Set with waterproof connectors
·Waterproof Grade: IP67
·Cooling: air cool
·Dimension: φ200X280mm
·Phase wire: 22mm²
·Insulation grade: H
·Working system: S9
·Color: Black
·N.W./G.W.: approx 25kg
·Package Dimension: pending piece
PS. For 180 PMSM motor, it’s maximum 135H 12000W motor.
The current product shell is a more industrial design, need to update the picture
Below are pictures for previous sample 180 135H mid drive motor, we plan to do some appearance updates for final sample, i will show you pictures when the sample finished.
Drawing
Here is drawing for whole 180 mid drive motor, if you need high-definition picture, please kindly ask me.
Please check the installation dimension, especially the diameter and width for threaded holes.
2.Match with sprocket SN520 13teeth, plan gear ratio 1:6.5
520-13 teeth
Test report
180 90H MAP
180 75H 7500W 99N.m
180 135H 12kw
with EM300 72V 350A, approx 102N.m peak
with EM300 82V 350A, approx 100N.m peak, 24kw peak
Application
Heavy Electric Motorcycle, e.g. Harly Scooter
E-motorcycle weight, approx 180kg+2*80kg
Speed: continuous 100km/h, peak 120km/h
Gear ratio: 1:6.5
Climbing slope: 50°@260kg
Battery: 72V80Ah
Tire: 0.6138 130/70-17
Calculations
For Controller
We suggest to choose sinusoidal wave Motor Controller EM72200SP with standards CANBUS,
EM72300P should also work (without CANBUS).
functions available for speed modes, anti-theft, cruise, reverse etc.
refer to below hyperlink.
http://www.cnqsmotor.com/en/article_read/VOTOL%20Lande%20Controller%20BLDC%20Programable%2072v%2048v%20Mid%20Drive%20Motor%20Controllers/837.html
Any needs, free to send e-mail: judy@tzquanshun.com
Hi any news about the new mid motor 180? Your website has shown the motor for more then a year but still not possible to buy.
1: Do you know if that new 180 series will be ready this year in 2020?
2: Iirc you last year said something about making the 180 motor with different power output. From QSMOTOR 180 90H up to QSMOTOR 180 135H, is that correct? Would like to know continuous and peak for both of those.
3: If your motor is still in beta testing, possible to buy a beta version? I don't care about warranty, and I can put that in writing for you if like.
Now this 180 8kw 90H mid drive motor is available now.
The unit price is $673/pc
The continue power is 8kw, peak is 16kw, it is encorder board, not hall.
The motor is available now, just for matching the controller it is still testing.
Thank you,
Judy
QSMOTOR said:
brazilianboy said:
Hi QSMOTOR,
Thanks
I live in Poland.
Please give me the contact of this person. Would be extremely helpful.
Thank you
Is the new QS 180 90h available with a 428 sprocket? Or do the 138 sprockets fit on the 180 shaft? Which controller will be best for the Motor?
The new 180 90H we are going to use 530 sprocket, when we ship the item we will match the 530 sprocket well.
138 sprocket does not fit 180 shaft, the size is different.
The controller we are considering is ND721200 or ND721800, still testing.
Thank you,
Judy
E-mail: judy@siaecosys.com
Wechat: gh13797405776
Skype: judy.gong5
brazilianboy said:
QSMOTOR said:
brazilianboy said:
Hi QSMOTOR,
Thanks
I live in Poland.
Pls tell your e-mail that i will ask him to contact you.
Thank you
Why use a 530 sprocket?? Even a 520 would be overkill, a 428 chain and sprocket should be the absolute maximum for this Motor, everything else is just more drag and weight. Will you offer 428 sprockets that fit this shaft, or maybe a belt driven system?
520 or 530 both ok, but 420 worry it could not bear so powerful.
For now, only sprocket type available.
Below is the spec:
Thank you,
Judy
Skype: judy.gong5
Mid drive motor rear wheel rim and front wheel rim
Rear whele rim: 17X4.25inch 17X4.0inch
Front wheel rim: 19X2.50inch 17X3.5inch
New sprocket shaft for 138 3kw mid drive motor
Now all the qs 138 3kw motor use new shaft, pls see below:
The old sprocket size is 6-4, new is 6-5.
Anyone have experience with running any of the QS motor with fardriver controllers? Any bad experiences?
QSMOTOR said:
Now we are trying to build our warehouse in European market, that the main purpose is to lower down the shipping cost.
Hi
Any updates on the warehouse in the European market?
High shipping costs is a major deterrent for me and probably many other potential customers.
Until now for our own testing, we think far driver is more stable than VOLTA controller.
