Hi all,
Lets say you have a 16s10p battery pack. I believe the standard practice in this scenario is to use a 16s BMS. This should balance each parallel bank, I believe you guys refer to them as sub-groups.
Since these sub-groups are a set of 10 cells in parallel, I assume the cells would balance somewhat automatically. Is it necessary to disassemble the pack and test each cell individually, or is it very low maintenance?
Also, are there any USA stocked 16s BMS that are worth using?
Thanks
Luke
Thanks
Luke
