Rix
100 TW
The Hatchling is looking sweet man. I am really excited to see your build outcome and 2nd person vids over the gnarly stuff. Got an ETA on completion?
Rick
Rick
Rodney64 said:I've just purchased a seat post 30.9 and 1 1/8 headset. All the info is on the new raptor 140 site.
Specifications:
Rear Shock Dimensions Compatible rear shock length & stroke: (267x89 / 240x76 / 222x70 / 216x63 mm). See table below.
Rear Brake Rear brake adapter is included in the kit and is suitable for 200/203 mm rotor and standard brake calipers (for example: Avid Code, Elixir). Two mounting bolts and washers also included.
Keylock Frame integrated key-lock for controller on/off.
Charger Integrated XLR charger socket with rubber cap.
Battery Compartment Inside frame width: 140 mm, max. opening height: 240 mm, max. battery pack size: 300 x 200 mm. For more info check drawing above.
Derailleur M10x1 threaded hole for standard derailleur installation.
Seat For bicycle seat post diameter 30,9 mm.
Side stand Standard bicycle side/central stand.
Controller Protector Aluminum controller shield with large ventilation holes. Larger (Kelly) controller shield also available. For more info check the product catalog tab.
Weight and material 10,1 kg; frame material: super strong construction steel (tensile strength 1200N/mm2, stronger than CrMo steel); frame side plates: high tensile strength aluminum.
Colour options - stickers White, yellow, orange, red, green or blue. For more info on colors check the gallery tab.
Headset Bearings Suitable for semi integrated 1 1/8'' headset bearing (bearings are not included in the kit.)
Bottom Bracket Suitable for BB shell width 83 mm, BSA (English) thread 1 3/8'' Left/Right (BB is not included in the kit).
Dropout Clamping type, maximum bolt size: M16, 10 mm slot. Swingarm dropout: 165 mm. Compatible with: Cromotor 155 mm size, spacers come with the motor. Crystalyte The Crown 140 mm, ask for additional spacers – 7 speed free wheel can be installed.
Hyena said:The key bits you need to get right are the headset OD is 44mm and you need an extra wide 83mm bottom bracket and crankset.
marcn said:you may have access issues with a 450lbs spring. We didn't, but we also didn't use the Fox shock commonly used on here.
We'll have something up shortly with some more information.
Mammalian04 said:Hyena, is there a good place to find all the specs (e.g. steering head size, seat post size, etc)? Qulbix doesn't seem to have a lot of that stuff posted (unless I missed it). I need to get crackin' on all the misc parts.
I am still baffled by the battery build so post up a 20s13p so I can copy you!
Mammalian04 said:marcn said:you may have access issues with a 450lbs spring. We didn't, but we also didn't use the Fox shock commonly used on here.
Thanks Marc, the 450 is in my weight range so I'll keep a lookout.
Hyena said:It's waiting to slap my big cro-style motor black and blue. How does that 350 phase amps taste piggy ? :lol:Merlin said:Haha, i see a sabvoton is waiting
I think they're underrated too. I'm looking forward to spending some time tuning and tweaking it.
The big solid aluminium base is a great heatsink. They're big and heavy, yes. But perfect for a high powered raptor build. I couldn't fit it on my stealth fighter previously as the frame was too narrow.
Merlin said:Mammalian04 said:marcn said:you may have access issues with a 450lbs spring. We didn't, but we also didn't use the Fox shock commonly used on here.
i had the same Problem.
but i have found a solution.
when you want to go with FOXRC4, a 450 Spring from CaneCreek fits.
Because the Spring isnt 3,64". It is 3.5. The Range of the Shock is 267x89. 89mm = 3,5"
When you set the Bottom Out to "hard" i dont see any PRoblems.
Did you check all the bags ? I'm just starting to put mine together and found the bottom bolt is in with the swing arm bolts and the top one in with the body/frame bolts.marcn said:One thing that's actually not mentioned on their website, although the product is available on their products page is the rear mounting hardware required for the shock. You'll need 2x M8x40mm.
I'm running a fox van R 400lb spring with no issues, other than I'm going to need alot of spacers to pack it out to fit the mounts.Also, depending on your rear shock choice (coil preferred), you may have access issues with a 450lbs spring. We didn't, but we also didn't use the Fox shock commonly used on here.
Hyena said:I'm running a fox van R 400lb spring with no issues, other than I'm going to need alot of spacers to pack it out to fit the mounts.
2x11mm spacers at the bottom and 2x ~5mm ones at the top
Merlin said:Hyena said:I'm running a fox van R 400lb spring with no issues, other than I'm going to need alot of spacers to pack it out to fit the mounts.
the Problem "exists" when you use a 267mm (10,5") Shock.
Because you need to use the upper first Hole.
Or the Middle one when you are above 1,90m tall ;P
or the last one when you are 2m :wink:
Mammalian04 said:Looks like a fox Van R. Does that come in 10.5? I am thinking of going with 9.5x3 just so it is a little better for shorter riders that may go for a spin (even though I am 6'2"...
Offroader said:Mammalian04 said:Looks like a fox Van R. Does that come in 10.5? I am thinking of going with 9.5x3 just so it is a little better for shorter riders that may go for a spin (even though I am 6'2"...
You should keep your bottom bracket around 14" no matter what shock size you use. If you want shorter riders to use your bike then lower the bike seat. If you use the moto seat this also won't be a problem.
You want all the rear travel you can get.
Mammalian04 said:Offroader said:Mammalian04 said:Looks like a fox Van R. Does that come in 10.5? I am thinking of going with 9.5x3 just so it is a little better for shorter riders that may go for a spin (even though I am 6'2"...
Noted. Thanks Offroader!
