QuestionMan said:Uschi K. said:Hi guys,
I was just trying to fit a bottom-bracket incl. crankset from race-face but i Looks like it is not wide enough to fit the raptor frame. The bottom-bracket is a Standard 83mm which fits the Frame well, but the crankset (especially the axle) seems not wide enough. Actually the crank is touching the Swinging arm (rear). Any suggestions or ideas what I should do else or what component I must buy? Thanks!
Kind regards
Lars
Ecruz just commented on this recently that his pedals/crankarms just clear the swingarm.
Could you take pictures of your crankset actually hitting the swingarm and is it on both sides?
How much more clearance do you need so the pedals do not hit the swingarm? I know that many bottom brackets come with 2.5mm spacers so you may be able to use these spacers to give you some extra clearance.
I must say it seems that ecruz, moonshine, Da-Ben, and even torque bikes all use truvativ bottom brackets and maybe truvativ cranks. These truvativ bottom brackets and cranks look to have a wider q-factor, by both the bottom bracket being wider and the pedals flare out more. From what I can see it may be the case that we may only be able to use wide q-factor cranks/bottom brackets. But again I have no idea just speaking from what I have seen works.
Truvativ bottom bracket looks to be wide.
hollowtech 2 bottom brackets look to be thinner
I had to use 4 spacers to clear the swing arm with my 83mm Chris King BB
