hello everyone
just finish to bild my ebike! and ready to drive.. but something is wrong..
I drive a bbshd with a infineon kh612 controller (that has his how plug to the CA) 14s lipo battery and a Cycle Analyst V3.03
Everything is just new!
what happen is a strange problem with the throttle, that happen only when the input throttle is connected to the CA and not when the throttle is directly connected to the controller.
The motor responds to the throttle really good when the wheel is not touching the ground, but as soon as I get on the bike and I try to ride, the bike responds really strange to the throttle, like intermittent power, come and go, like the throttle is following a sinusoidal curve.
Also I made another test, just tried to hold a bit the brake and give throttle in the same moment I noticed that the motor instead of go fluent it completely stop and restart, also if I tried to increase the throttle and the brake it do not stop completely the rotation but I can se that the speed of the chain ting is increasing and decreasing constantly..
Can be something wrong in the firmware of the CAV3? Should I try to reset/update it?
Just for let you know, the only settings that I changed on the CAV3 is the throttle input/output, battery tipe, speed and power limit. Also tried to put all back to the original settings but the problem is still there!
One thing I noticed, If I set the power control from Amp to Speed seems to work a little bit better but the problem is still there..
Please help!!
Please help!!
