Kunk222
100 µW
E-Bent -- Project
I'm a retired Mechanical Engineer living near Portland, OR. My current favorite ride is a beautiful Rans Stratus LE recumbent which I would like to convert to electric assist. Here are my design goals:
Basic information
- Location: Beaverton, Oregon, with an excellent bike culture and network of bike paths, trails and lanes.
- The area is somewhat hilly with 5 to 20% grades.
- Rider: 5' 11", 220#, with two blown knees (old football and skiing injuries). So,the beautiful hills around here are a definite problem, especially on a recumbent.
- Experienced motorcycle, bike and recumbent rider.
- Eexcellent mechanical and electrical skills and a shop full of equipment. Building up just about any kit or even doing a custom design and build for my Rans would not be a problem.
- My basic desire is to determine the best (for my needs) combination of drive type, battery and controller for my needs and bike.
Design goals - Needs
- Need to easily handle the local hills (up to 20% grades) with moderate pedaling.
- Range of 30-40 mi with light pedaling.
- Speed of 20 to 30 mph with light to moderate pedaling.
- Safe Lithium battery technology i.e. LMO, LFP, NMC
- High quality BLDC motor and FET ESC (controller)
- Must be cost effective (under $2K, system total)
- Must be reliable.
Design goals - Wants
- Relatively light combined drive and battery weight. The bike and rider are already too heavy.
- Forward, frame mounted battery (and drive ?) for better weight distribution.
- Estimate 750 to 1KW needed (OR max is 1KW and 20 MPH)
- BLDC, hub motor or mid drive ( Bafang or ?)
- High efficiency drive with low parasitic losses (heat, cogging, drive train drag)
- Rugged, 30-40 A ESC with 9-12 FET topography (why don't mfgs use IGBTs ?)
- Cycle Analyst V2.5 or/= would be nice
- Very clean and water resistant installation...It's Oregon. It rains...a lot.
Summary:
My intended use is a daily, local area ride on bike paths, roads and hard packed bike trails. Typical grades in this area are 10% up to 25% with a distance of 1/8 to 1/2 mile. As I said, my knees are shot so that I really need help on the hills rather than speed. Quality is also important. I have absolutely no use for low quality and unreliable equipment.
Would a Bafang 750W, 48V BBS02/= make sense for a bike like my Rans Stratus LWB Recumbent? It seems like it would be efficient with great hill climbing ability. With both the drive system and battery mounted forward the weight bias would be closer to balanced.
Another choice might be a different mid-drive or rear wheel geared hub drive. I do worry about the reliability of most geared hub motors. At the same time, the higher torque and light weight of a geared hub or mid-drive is desirable.
I'm looking for ideas and suggestions for the best combination of components for my needs. I can build just about anything. What I need is good information from the experts (Kepler et. al.) to get off to a good start on this project. I also plan to video my adventures in building and riding the bike.
Thank you all, in advance, for your help...kunk
