I'm building an electric car battery pack and this will use 84 20 amp hour cells.
24 of the 84 cells will have 1 amp hour higher in capacity.
So 24 cells will be 21 amp hour and 60 cells will have 20 amp hour.
Assume the 24 cells move perfectly together in balance, and the 60 cells move perfectly together in balance. What will happen in the long run if I use all these cells without balancing them, but I stay within the safe voltage limits of the weaker cells?
Assume on the weaker cells I stay within 3.3 and 4.1 and on the stronger cells I stay within 3.3 and 4.1. Will I ever need to balance charge the pack if all the cells stay within balance in their 24 / 60 groups?
