enrengineering
- Joined
- Apr 2, 2020
- Messages
- 41
Hello
On september of last year I was taking apart a battery I bought, the BMS failed (due to overdischarge), I checked all the voltages of each cell and the voltage of the whole pack and everything was ok. I was trying to separate one cell of the whole pack to find out any part number to identify the cells and find the specs/datasheet of the cells to find a new suitable bms. I used a worn out metal spudger (here my mistake) and managed to scratch the wrapping of the pouch cell, nothing caught fire and no smoke was released, I immediately covered the scratching with electrical tape. I kept an eye until now at the whole battery an also the affected cell but nothing changed, same voltage and physically looking the same. I'm asking if I need to dispose the affected cell or if I can do anything to save it. The cells are the LG P2.7 arranged in a 14s1p configuration, the battery fully charged is at 54V and I need a 48V system, most probably if I need to remove the affected cell I can live with the 51-ish volts.
Here's the affected cell and the electrical tape covering the scratch
And here you can see the scratch on the wrapping
Any advise will be greatly apreciated.
Thanks, Henry.
Thanks, Henry.
