markz
100 TW
No, I am serious....I have never hit a pothole in my life. However, around here.........few potholes!
John in CR said:madin88 said:John it really makes no sense to talk with you since you do not understand what i'm trying to point out.
For offroad, MX motos run a smaller wheel on the rear for better traction, so you've got some learning to do there too. Regarding potholes, sure I've hit a few, but frankly I ride with focus and avoid them, so maybe you should pay closer attention while riding.
Back and forth with you is exhausting. There's nothing I can learn from you, and you think a bit too highly of yourself to learn anything new, so I won't waste any more time.
There's not be a single thing you've posted that I haven't understood. Since you don't know how to tune your suspension, I'd suggest getting with MadRhino, who on one of his bikes runs an Xlyte 54xx which weighs about the same as HubMonster. For offroad, MX motos run a smaller wheel on the rear for better traction, so you've got some learning to do there too. Regarding potholes, sure I've hit a few, but frankly I ride with focus and avoid them, so maybe you should pay closer attention while riding.
That's fallacy. It depends on the wind...Rix said:Cant' we all just get along? Okay, I am being a smart ass. Sorry guys. But, John in CR is right, no matter how you slice it, the smaller the diameter of the wheel is, the more work you get done under load with less amps.
Arlo1 said:That's fallacy. It depends on the wind...Rix said:Cant' we all just get along? Okay, I am being a smart ass. Sorry guys. But, John in CR is right, no matter how you slice it, the smaller the diameter of the wheel is, the more work you get done under load with less amps.
markz said:Arlo1 said:That's fallacy. It depends on the wind...Rix said:Cant' we all just get along? Okay, I am being a smart ass. Sorry guys. But, John in CR is right, no matter how you slice it, the smaller the diameter of the wheel is, the more work you get done under load with less amps.
What depends on the wind? Getting along?
the most important question: did you adjust voltage and current settings?Rix said:Based on my real world findings, load wise, the 5405 was getting more work done with 17MC wheel over the 18 or 19. Ironically the 5405 was the only motor that didn't pin the DC AMP draw to the limits of the controller. Load inductance factor coming into play. The 5404 did, and the 5403 did max out my controller. The 5404 running the 17MC had the same perceived acceleration as the 5405 with the 17, 18 and 19MC wheels, and the 5403 was noticeably slower off the line over the 5404 and 5405. Infact I would go as far as to say the 5403 felt slower with the 17 then the 5404 did with the 19. Anyway, I contacted Kenny at Crystalyte and asked him why the 5404 and 5405 had close to the same acceleration and the 5403 was a bit slower, his reply was this. The 5403 uses .083 wire and has 3 turn winds, the 5404 uses .083 wire and has 4t winds, and the 5405 uses .065 wire and has 5t winds. So the copper fill between the 5404 and 5405 are close even though the 5404 has one less turn, and both motors have quite a bit more copper fill than the 5403. I know in the grand scheme of recent conversations, I have stepped back wards from the topic of discussion between Arlo, Markz, and JohnCR, but thought some folks would be interested in my findings.
thats not true.John in CR said:Many, if not most, motorcycles have greater unsprung weight, so of course it can be properly controlled. No other shock will fit on my SuperV, but it's a street bike and I have no problem with it riding like a 70's land barge Cadillac. It's only scary because it's so quick and fast, but in terms of handling like any 2 wheeler riding it requires using experience and common sense.
madin88 said:the most important question: did you adjust voltage and current settings?Rix said:Based on my real world findings, load wise, the 5405 was getting more work done with 17MC wheel over the 18 or 19. Ironically the 5405 was the only motor that didn't pin the DC AMP draw to the limits of the controller. Load inductance factor coming into play. The 5404 did, and the 5403 did max out my controller. The 5404 running the 17MC had the same perceived acceleration as the 5405 with the 17, 18 and 19MC wheels, and the 5403 was noticeably slower off the line over the 5404 and 5405. Infact I would go as far as to say the 5403 felt slower with the 17 then the 5404 did with the 19. Anyway, I contacted Kenny at Crystalyte and asked him why the 5404 and 5405 had close to the same acceleration and the 5403 was a bit slower, his reply was this. The 5403 uses .083 wire and has 3 turn winds, the 5404 uses .083 wire and has 4t winds, and the 5405 uses .065 wire and has 5t winds. So the copper fill between the 5404 and 5405 are close even though the 5404 has one less turn, and both motors have quite a bit more copper fill than the 5403. I know in the grand scheme of recent conversations, I have stepped back wards from the topic of discussion between Arlo, Markz, and JohnCR, but thought some folks would be interested in my findings.
referrting to 4T setup:
on 5T it would be 4/5 x current and 5/4 x voltage
on 3t: 4/3 x current and 3/4 x voltage
would not be easy because you need 3 different batteries additionally you would need to consider that 3T motor will have more losses outside the motor if phase wires are the same.
in the simulator it would be come quite close if you play with controller resistance to see the changes at same battery power. acceleration will change. ok, not much but it will.
markz said:So copper fill of 3, 5, 7 (odd) and 2, 4, 6, 8 (even) are all the same, right.
What about the characteristics of going from a 4T to a 5T, or 4T to a 3T?
markz said:Sure in whatever motor you want Rix, but I got the mxus 3000w.
I guess I was trying to get the difference in copper fill 4T and 5T. And the more the better right?
I remember people chatting about that. Cuz the strand # in front is different. 21x4T and so on. IIRC its not much, 5% to 8%.
speedmd said:Wondering if the existing constants can explain this mathematically via several of the existing motor constants or are we dealing with some sort of additional thermal /torque constant for each motor to best explain the motors wind /constructions robustness to stalling /running a taller gear / driving higher torque loads with a certain duty cycle.
speedmd said:That is not how I see it Punx. It is more copper / lower resistance is always better than higher resistance in the coils. Certainly you need a reasonable KV that can be handled. The question is, what exactly allows a motor to effectively drive a bigger wheel with out risk of harm to itself? What other things need to be looked at?
Do we sacrifice the amount of steel, making more room for copper? This trading ultimate magnet strength for resistive losses? It would also lower the iron losses at higher speeds. Do we go to fewer poles? Or is it simply a larger diameter stator? Lots to learn here without taking a stand at a very low level of understanding (at least in my case) the real world trade offs.
