Sound like it works well. When you get full sun you can use more assist.
If you have an ammeter on the battery, you can tell whether you're charging or discharging. Using the ammeter, you can see what speed gives you zero net battery current. This would be the same as running without the battery. If that also keeps track of amp-hours, you can tell how much of the capacity you've used or need to charge back.
