Solid state batteries?
Missouri
So I came across a company selling a power station based on solid state batteries:
That is 602Wh per their claim. The packs are 16.2v, so 3 would be a 48v battery, and 4 would be 72v. Which means 12.5Ahr for 699... of course a lot of extra crap their we don't need, like a big case, inverter, charger, etc.
Still, the unit is just 17lbs, so if half of that is crap... 8.5lbs in batteries. Maybe less? They claim 25% lighter than a standard battery. You can see the rought size and shape of the battery here:
Of course, it might be tricky to find a BMS for it, especially since SSB's can charge and draw power way above what a Li-Ion can do.
Tempted to see if they sell "replacement batteries" for the units...
Maybe it's the same thing as the bare batteries in this thread?
Such as:
Less unneeded junk to remove with those, like the inverter to household current.
Kinda.
Two of those in series (7s for the discharge rate) would be 24Ahr and 968Whrs, and 4.6Kg.
Compared to a 20Ahr 52v battery with 1040Whrs and 6Kg.
At almost double the cost for 1.4Kg, or about 3lbs savings.. not sure it is worth it.
Now the 30Ahr model, at 6Kg or ~13lbs assuming 2 in series, that is pretty energy dense, basically 50% more power for the same weight as the 20Ahr Li-ion battery... and no fires.
Edit: I just saw they don't properly update the voltage, and the 12S is actually 44v. So that is really 6.5 lbs for 1320Whrs.
All in an approximately 3.2x4.5x7.8 inch package.
Tempting...
