Cam3roon2k41999 said:
Thanks for the info on that my turn signals that I have installed now are ok but they seem pretty close together so I preferably would like them spaced out more but it's one whole unit and it's running directly from 72v,
I'll have a look into those strips you where talking about it sounds interesting, someone told me to 3d print some 90° angles of aluminium or steel for turn signal mounts but I don't have a 3d printer
You can almsot certainly just go to the hardware store and find something (or a set of somethings) that will let you bolt something together to space things out more.
If you like the unit you have but it's just not wide enough, you could get a second identical unit, and put each one sticking out to the appropriate side as far as you need to, using the hardware store stuff.
Then move the wire for the righthand turn signal off of the left hand unit to the righthand unit, and add wires from the power, ground, tail, brake lights on the lefthand unit to the righthand unit (so you only have left turn signal on the left unit, and only right on the right unit, but everything else on each one is wired the same between them).
The strips I referenced are available in various types; they could be used on your frame and/or forks, depending on layout and design of the bike, or you could use hardware store bits to make a vertical or horizontal mount for them.
There are also many decent (and some good, and a lot of crappy) motorcycle lights and signals that are designed to just bolt onto various bike designs, some generic and some specific to a particular brand or model of bike. Some stick out more than others, and most could be made to stick out more with hardware store bits and bobs.
I used a set of rear signals from goodwill that are meant to stick out farther, on the front of SB Cruiser to stick out *less*, by bolting them together as a "wing" under my peek-around-cars/corners mirror. Images attached at the end of the post, if useful.
My SB is a little bit of a death trap at the moment as when I first built the bike with 26" wheels I didn't have a thru axle rim to fit the triple crown forks and it was going to cost me £400 for a rim lol
There's no such thing as a "thru axle rim". A rim is just a rim.
The hub you use to build the rim (and spokes) into a wheel, now *that* you would need to get in thru-axle version, if the fork you have uses thru-axle. Alternately you can buy a whole wheel that already has the right hub for you.
Do you have any ideas on any decent forks that are suitable for my SB and quick release or wheel nuts,
Looking forward to you're reply
That I don't know. There are a number of threads for various clone "stealth" frame builds; you can look thru them to see if one has the same headtube as yours to see what fork they used, and if that suits your application.
FWIW, a good fork is likely to cost more than a good wheel, just based on stuff I've seen posted around the forums over the years.
