skyungjae said:
https://electricrt.com/sur-ron-20s-72v-30ah-drop-in-battery-upgrade/
Looks like there will be a drop in solution for a decent battery upgrade.
Something isn't adding up here, maybe my math is wrong?
They claim a 72 v 30 AH pack at 2460 watt hours, but that would be a 2160 watt hour pack and not 2460 they are claiming. 72 volts * 30 amp hours = 2160 watt hours.
If they wanted to get a 2460 watt hour pack using samsung 30Q cells, they would need to use 228 samsung 30q cells. This would mean they would have to pack the cells in tight if they are using a removable battery or a similar case to the stock battery case. Highly unlikely anyone but DIY hobbyists like us would pack the cells in tight and not use spacers.
I find it highly unlikely they are going to use 228 samsung 30q cells, they could but just doubtful they would do that. That would be a decent pack if they did though.
I wonder if they got their math wrong and intend to use a 20s10p configuration giving a 72 volt 30 amp hour pack. But that would be about the same capacity as the stock battery. This would also use 200 cells, similar to the stock battery which uses 176 cells.
As we know the range is kind of limited on the stock battery. If we use a higher powered battery and turned up the power with an aftermarket controller we would get an even worse range.
I personally would like to have at least a 2800 watt hour pack, that would give you a decent range, especially if you are going to be turning up the power of the bike with a new controller. If they did manage a 2460 watt hour pack with 30Q cells, that would be somewhat acceptable, but at the low end of what would be acceptable.
