Eastwood
- Joined
- Jan 13, 2021
- Messages
- 1,479
Finally, another update!
Ended up cutting the main top motor mount to make room for the battery. Not worried about the powder coat, this part will be covered with rubber.
Gutted the bottom side of the gas tank to allow for the battery to fit. The battery shape/cell holder seems to fit nicely with the fuel tank. As of now 300 cells, 20s 15p = 63 amp hours. The original thought was 340 cells 20s 17p, but we’ll see I’m still working on the battery configuration. Was considering 26s or 28s but would rather have more groups of parallel for range. Really don’t need any more than 50 mph with this build since this is strictly for technical trails, Enduro and or hard Enduro.
Controller as of now will be FarDriver ND72850. This will give me 450 battery amps, I’ll just use that much if I’m drag racing a buddy or somthing. I guesstimate to only be pulling about 250-ish DC amps maybe 450-ish phase for trail riding but we’ll see once I get to test it in the real world. With only pulling 250-ish dc amps and having at least 15 groups parallel should give me great efficiency, and not much heat buildup. 15p would technically give me a discharge of 675amps. Will be using 1.0 mm copper busbars and the spot weld will be with nickel .15mm, see image below… The 1.0 mm copper busbar’s are probably overkill, but it will just help add with efficiency.
Got the handlebar accessories/cockpit sorted out. Left side - headlight control, regen which is the horn button/momentary switch. Then the turn signals switches will be used for the forward, neutral and reverse.
Right side - 3 speed switch. Thumb throttle assembly- which includes the voltage reading, power button for the controller and of course the throttle. Same throttle assembly I use on my Enduro clone build. I love the throttle control with this particular thumb throttle compared to all the other ones I’ve tried. I always keep an extra throttle assembly with me in case the plastic thumb lever snaps off, which I’ve done before in the middle of a hill climb
No footbrake with this build, rear brake will be left hand brake, right brake lever front brake.
Went with Rogue ATV handlebar grips as it has a notch that works with a thumb throttle. Also easier to reach the regen button.
Handlebars - Pro Taper woods high, Contur oversized. Picked up a cheap headlight off Amazon, looks great!
For the seat, got a new seat cover and new foam. I had purchased a seat off eBay that was listed for my model and had finished recovering but realized it didn’t fit once I bought the gas tank. So anyways, got another seat ordered and will recover. In the picture below, it’s just the seat cover and foam it’s not attached to the seat pan yet. Ordered an air intake airbox which will be modified to fit the controller with the subframe. The airbox fills in the gaps for the side plastics.
Thanks to member rivvs with supplying the contact for the custom busbars!! Thank you sir
