extreme999
I've purchased an assembled DIY ebike with a 1500W rear motor and a 48V battery pack.
I have an unspecific inverter/controller which does not have any plugs/flying leads for the SW900. However I did note some solder/lead bits on the pcb marked RX, TX and what I think was 5V (I'll have to get my magnifier out to double check), there's currently no leads/cables soldered in to the identified solder points.
The SW900 has one SM-5Y socket with Red, Yellow, Blue, Green, and black (linked to the second 2 pin SM-2 socket).
The second SM-2Y socket has White and a Black linked to the first socket
According to the blurb enclosed with the SW900, the colours and their task is as follows;
White - DD
Black - Ground
Green - RX
Blue - TX
Yellow - DS
Red - D+
Am I on a loser before I even start?
Thanks in advance for any help you can give
White - DD
Black - Ground
Green - RX
Blue - TX
Yellow - DS
Red - D+
