ElectricGod
amberwolf said:Since there is a pullup voltage on the hall signal line from the controller (or tester), then a steady voltage can mean either a bad connection from the hall itself to the output pin you're testing (anything from a bad crimp at that pin, to a broken wire anywhere from there to the hall, to the solder joint of that wire on the hall lead), or it can mean a failed hall.
Pull-up voltage? Really? Are you sure? Halls tend to never swing from 0 to supply voltage. I've played with probably 10 different models of linear and digital halls and all of them had a minimum voltage that was more than 0 volts and maximum voltage that was less than supply voltage. Is this perhaps what you are referring to as a pull-up voltage?
Halls used in a motor should swing to their maximum output voltage in the presence of any magnet. Halls are usually powered at something close to 5 volts so I commonly see 4.3 to 4.7 volts max on the signal leg of the hall in the presence of a magnet. If the hall doesn't swing...it is likely bad, but sometimes wire insulation gets split and creates short too. I've popped all 3 of the halls in motor from that happening against the scooter frame. Everything was fine one second and a second later no motor action at all. I thought I burned out the controller and was just 3 cheap halls shorted to the frame. PHEW!
