I participated in the BMS development, but Steve Ciciora and Derek Barger (denverCNC.com) did the circuit design, etc. Thus, the details are more theirs than mine, so I'm not the one to ask for the design schematic.
Also, the BMS we use on the KillaCycle is only suitable for drag racing. As it is built, it would not work at all for a daily driver EV.
You ask about fast charging, and you don't understand how we charge so quickly, but you should take the time to read what I posted completely.
I'll say it again. We only take about 700 W-hrs per run. Thus, we can recharge in about 4 minutes. 700/10400 = 0.067 hr = 4.038 minutes. Often, we use considerably less than 700 W-hr so it takes even less time to charge. The charger can draw 50 amps from the outlet. The charger output wattage depends on the input voltage. If we get 240 volts, the charger wattage is 12,000 watts.
10,000 watts into 375volt works out to 27 amps. We are 11 cells wide these days, so that gives 2.4 amps per cell.
If it were someone else on the team, they would put their own name at the end of the post. Wouldn't you?
Bill Dube'
Doctorbass said:
Wow !!! it's very great to have you here ! and i think all of us appreciate the precious advice you share to us!
Welcome!... I see Bill Dube under each reply, is that you? or someone else of the team?
I began to play with A123 cells from 5 months now and the way i got them is by getting deffective 36V dewalt pack from the service center and by removing the 2 or 3 deffective cells inside and keeping the great one. these cells cost me under 5$ each and i got around 200 from now.
I tested and retested each cells and i learned alot about them. People here are using these and appreciate alot these becose of their competitive advantage with ebike. The main goal now is to desing a great charger and a great BMS. we consider many idea about charging them but the most stable and secure seems to use one charger per parallel group.. 20s would mean 20 charger to get the CC-CV. about the bms to protech the vattery about the LCV and keep them balanced, some member of that forum designed pretty great and simple circuit about that, BUT FOR SURE ,WE WOULD BE INTERESTED TO KNOW YOUR DESING :wink: we found a PDF explaning the base of the circuit but i admit that i dream about getting your schematic
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I missed something and i would appreciate if you could explain me that:
a 10kW charger for a 374V 8s pack is around 3.5A of current to recharge each cells right? so how could you charge the pack in less than 4 minutes?
4 min = 34.5A per cells for the charge and that would mean 276A for the 8p and at 374V it's 75600W of power to charge the pack from 0 to 2300mAh per cells and your charger have 10kW?
Doc
