The thing about God is that we humans try to understand Him beyond the simple Biblical explanations, and we simply don't have the intelligence necessary to reach out very far.
There are so many unknowns.
Here's one: The universe, during the big bang, actually expanded faster than the speed of light allows. Humans don't quite know how that's possible.
As far as we know, nothing can travel faster than the speed of light. The universe is 13 billion years old (Wikipedia) but has a diameter (observable) of 46 billion light years. Somehow the universe is four times bigger than the speed of light allows. The universe should be slightly less than 13 billion light years in diameter.
Therefore, Einstein's theory, although proven correct countless times, has been broken.
Newton's laws of motion, which can be mathematically calculated perfectly (hence, you can build a roller coaster in which you bring the train to the proper height, and it can ride out the track successfully every time), cannot explain motion that breaks those laws.
God still has the drop on us.
Keep in mind, however, that magic is entirely real. What seems completely normal to us is magic to the past.
In other words, if you had a walkie talkie at one end of Philadelphia, and gave the other to Ben Franklin, you'd probably have the town ready to declare you a witch, even though they hadn't really gone after witches in a hundred years, and you would most likely be dangling from a rope for your black magic.
Here's another thought they never bring up in time travel movies: Everything is in motion. If you went back in time five minutes, wouldn't you be thousands of miles away from earth, out in space (and instantly dead)?
The earth is not only rotating 1000mph at the surface, but is moving even faster than that as it revolves around the sun. It's moving at a speed of 66700 mph through space.
Divide that by 12 (for a five-minute time travel) and you should find yourself about 5000 miles away, giving you a fantastic ten-second view of our beautiful planet before you lost consciousness.
Michael J. Fox somehow traveled back in time thirty years AND found the correct spot in space.
