SplinterOz
SplinterOz said:Arlo1
You have to remember that the PWM is turning on and off many times (100's I think) per electrical cycle of the motor. The position of the Halls (either mechanically or electrically) has no effect on how well the PWM turns on and off. The timing can only effect the trapezoidal change event timing out of the controller so I am with toolman2 here (literally and figuratively) I think that RPM would probably be more than 90% of the issue if not 100% of it.
Bad form to reply to yourself but here goes...
I have re-read what you said and basically you are saying that due to the fact under load you are putting more energy into the stator the flux will build quicker therefore reducing the delay that the timing advance is meant to overcome.
Here is a good question then... is the delay a factor of the motor or the controller? When toolman2 and I were measuring it with my motor the delay appeared to be a static value of time. This of course translates to a linear increase in retardation in degrees. From memory this delay was even present and constant when we had the motor being driven mechanically and the controller (using the hall sensors from the turned motor) was driving a non inductive load (in our case 3 x 240v halogen down lights). Based on this testing I think that we are fixing a controller delay not a motor delay and that we are really tuning the controller in relation to the number of poles
toolman2 does my recollection sound right to you? Burtie, Jeremy does this sound right?
or should I just shut up :?
