gothicsurf
Are there any hub motor kits available with true torque sensing (not PAS) from anyone except Grin?
neutro said:...
Just had a look at the heinzmann site and details of the torque sensing option seem to be only on enquiry.
MadRhino said:
neutro said:MadRhino said:
Had a good look through that pdf, thanks for posting it. Still no details on prices apparent on the site. In my experience that means it's out of my price range. The fact that it's german manufactured likely confirms that.
I realise that I'm hassling you, fella, but could you suggest a torque sensing solution for a Qulbix/Risun style frame?
MadRhino said:Torque sensors are many, few are durable, few are included in kits. No matter the one you decide to install (most of them will fit), you will have to inspect often and never ride it slack.
I was meaning the torque sensing BB itself. The torque sensor pickup and bearings must be tight. They often get loose after some time riding, so the torque sensing BB’s must be inspected regularly. Most of them wear enough to become impossible to adjust after 4-5000 km. Like I said they are many, of different quality and reliability. And, as noted previously, most of the softwares to control them are inadequate. That is why I recommend buying the best, to those who are going this route. Most PAS that I have seen are cheap stuff and not tuned properly. Try not to be one of those.neutro said:Do you mean never ride it with a slack chain?
AHicks said:Junk software, that is usually supplied with inexpensive controllers and bikes, will NOT leave a good impression for the rider.
The more adjustable it is, the better you're going to like it.
Point is, a sensor senses motion or torque. That's the easy part. It's what happens after that that separates the men from the boys.
MadRhino said:Try not to be one of those.
