dirttorpedo
- Joined
- Mar 21, 2017
- Messages
- 53
Went for a ride this morning. Was powering to the top of a big hill and I lost power. I wasn't hitting it particularly hard because it's muddy where I'm riding. And I don't believe I smoke the motor I wasn't anywhere near my thermal cut offs. But I haven't been able to get any response from the motor under power. When I walk or pedal there's a lot of intermittent resistance. It feels like a spin catch spin catch spin catch with the resistance being every couple inches. It was a rough 7 and 1/2 mile walk home.
I'm running a crystalyte 4065 with a powervelocity controller and a cycle analyst. I've been running this setup for about a year now. I'm showing accurate speed on the CA, so (fingers crossed) I think the Halls are fine. I've also checked the connections coming out if my controller with a multimeter and have verified that the controller probably isn't the issue.
So my plan is to test the halls for voltage using the spin method. And then open up my motor to see if wires may have been severed. I had to do some rerouting or earlier this weekend because I had to replace a tube in tire. I suspect maybe I strapped the cables down to tighten one of them got pulled.
What do you guys think? Would that cause the type of issue I'm having?
