That looks like an early Crystalyte motor to me, but I can't say for sure. And it doesn't really matter. It's an old design, so probably not super efficient by today's standards.
Motors often have a wattage rating, but that's only a rating. Motors don't have native wattages or voltages, and saturation currents are something most of us don't even approach.
If you have a battery and controller you can use to bench test the motor, you can figure out its RPM per volt. That will let you know how many volts you need to cruise at your desired speed-- aim for cruise to be about 75% of the free speed.
Your motor's ability to make power is limited by heat, so gross efficiency, physical size, and thermal mass all play a part. To the nearest approximation, any of these direct drive hubs should tolerate at least 100W per pound of hub, for some useful duration.
If it's a geared hub-- if it is, the axle will turn much more easily in one direction than the other-- then its reduced heat rejection ability will limit how much power it can tolerate versus an equally sized direct drive hub. And if it's a brushed motor (two thick wires going in, rather than three), it will have lower efficiency, thus more waste heat, thus less ability to use power without burning itself up.
Based on the apparent size of that motor, and assuming it's brushless direct drive, I'd guess that you can feed it 25 battery amps pretty much no matter the other specifics.
