TSDZ2 OSF Throttle
bpratl
Gloucester, MA
I need help is setting up the throttle configuration for my 860C OSF TSDZ2 motor.
Everything is working well including brake shutoffs and motor PAS speeds.
I believe that the hall throttle sensor is wired correctly because it was working
great with the older display so I think that I have overlooked something in the setup.
After rechecking the 860C setup I found out that I had enabled the temperature reading which disabled the throttle.
You can't run both on model TSDZ2. It is now working great.
Not sure what you mean by normal. A few years back normal was jumps and bumps now that I am older normal is smooth gravel
and easy riding. It now hurts when I fall.
My TSDZ2, OSF v1.1 and 860C does not seem to have adequate power when using the throttle from a dead start.
PAS seems to work fine but I would like more power from the throttle. What OSF setting do I need to change in order to get more acceleration on startups? Would V20.1.3 give me more options?
