dumbass
Calling all controller geeks. OK, I have a twin 24v brushed motor setup but normally only use of the 1 motors and the other is for added power when needed or a redundant. Currently each motor has it's own freewheel, on/off switch, controller and throttle. I would like to maintain the twin or redundant setup but change to a single throttle for both motors.
I have already tried connecting both controllers to one throttle with no success. I have been told that I would need to leave off the positive lead from one of the controllers to make it work. I tried this and the motor without using the pos. wire did not run at all. Of course even if I could make it work by leaving off the pos. wire from one controller this is not an ideal situation because it would require that controller to be active even if not in use. I am wondering if my solution is to use diodes. I say this because if I wire the 2 controllers to the single throttle each motor will work provided I only apply power to 1 of the controllers. But if I apply power to both controllers the controller that was switched on first is the only motor that will run. Therefore, I am thinking there is a voltage feedback causing the second controller to not function. By installing diodes this should correct the problem. Any thoughts?
The question is what type and size diodes do I use and where do I install them? Do I install them on each wire of both controllers? Just figuring out which wire is doing what is a big PITA. Here's the voltage reading across the wiring both in standby and with the test motor running at a slow rate of speed.
The throttle to my knowledge is a hall 3 wires; throttle using 1 each white, black and red wire
Motor IN STANDBY
WHITE TO RED = 3.54V
WHITE TO BLACK = .875V
BLACK TO RED = 4.42V
MOTOR RUNNING AT SLOW SPEED
WHITE TO RED = 2.26V
WHITE TO BLACK = 2.14V
Thanks for any help you can give me,
Bob
Motor IN STANDBY
Bob
